3
This discussion topic has been answered Discussion topic: Sky glass puck remote
This message was authored by: ChristineT
The batteries in our sky glass remote only last a few weeks which is a lot less than the remote for the main tv remote
This message was authored by: Fothergill1 Answer
Re: Sky glass puck remote
@ChristineT I had the same issue when I first joined the streaming platform about 3 years ago and Sky readily replaced it for me and the batteries in the replacement remote last for months.
@ChristineT  Sky Glass is the TV, Sky Stream is the puck,  there is no such thing as a Sky Glass puck.
If the batteries are only lasting a few weeks either the remote is defective or a button is stuck on the remote.  How long have you hasd it, is it in warrantly?  https://www.sky.com/help/articles/warranty-sky-glass
If not you'll need to purchase a new remote
  1. Go to Amazon.
  2. Search for Sky Glass accessories.
This message was authored by: Stephen+Mourton
@ChristineT   Are you infact a Sky Glass customer because this is the Sky Stream forum.
