Discussion topic: Sky glass puck Alt Location
This message was authored by: MJG4
Can I offer to pay a one off fee to use my sky glass puck for a 2 week break in the UK?
Re: Sky glass puck Alt Location
@MJG4  I don't believe thats possbile as the t&C's are specific in that Gass TV's/Strea m pucks can only be used at the account holders  registered address.
@MJG4  Sky have sky go available on mobile and laptops for the intended use you require
using sky hardware away from it's registered address is prohibited under the terms and conditions you agreed to
Avatar for MJG4
thanks yes im aware of that it was to save any dubiety about the terms and conditions i do think its something that should be considered by sky for a set amount of time away from the home for either a one off payment or an added subscription cost. I have sky go on mobile devices
