Discussion topic: Sky glass not streaming
This message was authored by JaneS88 This message was authored by: JaneS88
Sky glass isn't streaming/loading. Internet connection is fine.
is there a technical issue.
No issues detected in my area when I check status.
This message was authored by Kevin-7248 This message was authored by: Kevin-7248
Re: Sky glass not streaming
Hi @JaneS88
Can you explain further in what you mean it is not streaming? Does the TV turn on? Is there an error screen or is the screen blank?
Thank you for the additional info to help you with your query.
Sky Glass 65”
Sky Fibre 500 WiFi Max
Been a sky customer through the ages from before HD boxes were a thing! When sky was a box you had to wind up to work 
JaneS88
The TV is on. When I select a programme to watch it just says 'loading' then says there is a technical fault. All programmes not just the live sport I am trying to watch.
This message was authored by Jporch316 This message was authored by: Jporch316
@JaneS88
Have you tried pulling the plug for a few minutes
43inch and 55 inch Sky Glass & 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims. Pretend guitar aficionado .. rock on!
JaneS88
I'll try that
JaneS88
All sorted. Didn't try that initially because I have 2 glass TVs and they were both the same.
Thank you
@JaneS88
Just like most modern devices the sky glass needs a power off / on occasionally - I have mine plugged into a Tapo smart plug so that I can use an app or Alexa to power it off an on
just a little bit lazy 😂
