Discussion topic: Sky glass mini box glitch
Message posted on 25 Mar 2025 10:05 PM
Sky glass main tv ok but mini boxes glitch. Picture freezes but sound ok then it catches up. Seems worse with live tv. However just watching channel 4 now and screen has gone blue - no sound
Message posted on 25 Mar 2025 10:50 PM - last edited: 25 Mar 2025 10:52 PM
Re: Sky glass mini box glitch
Hi @Davet26
It's a Sky Stream Puck. It could be to do with the WiFi signal it's getting compared to you Glass. Sky say that you need 25Mbps for HD and 30Mbps for UHD. You can check the speed your puck is getting by opening netflix> going to the left hand menu > get help > connection check.
It would be best to run it a few times and take an average.
If your speeds aren't as required, you can either look at getting a wireless extender from your ISP or connecting it via ethernet and turning WiFi off in the settings or using homeplugs. Or even a simple repositioning of the puck could help.
Let us know the outcome and the community can try and assist further.
MikeAlanR
