Discussion topic: Sky freezing
Message posted on ‎16 Mar 2024 01:39 PM
Sky freezing
My picture keeps freezing and resetting
Message posted on ‎16 Mar 2024 01:53 PM
Re: Sky freezing
@Alan6810 very probably insufficent wifi signal reaching the puck. Try moving your puck and the router out in the open so they are not blocked by things round them. However in some homes you msy need some form of booster. Ethernet cables where practical are another possibility.
Message posted on ‎16 Mar 2024 02:58 PM
Re: Sky freezing
@Alan6810 One of the main reasons for freezing is the quality and speed of the Wi-Fi signal being received at the TV/puck and not that being received at the router. This can be checked with the Netflix App (Get help > Check network) and is often much less than you might expect. The minimum speeds recommended by Sky are as follows:
HD = 25mbps
UHD = 30mbps
HD + 1 puck = 30mbps
UHD + 1 puck = 35mbps
If your speed at the TV is borderline try connecting via Ethernet cable. If this is not practical you can use powerline adapters (about £30 at Amazon). Note the Ethernet port on the Glass TV (& pucks) only supports 100mbps so don't waste money on the more expensive 1gb powerline adapters.
If my post has solved your issue please mark as an "Answer"
