Discussion topic: Sky cinema
This message was authored by: Hannah243
Sky cinema
Can I cancel Sky cinema?
Re: Sky cinema
Absolutely.
As long as you're not in a long term contract. If you signed up to a discounted minimum term then you probably can't but have a look on your account and see if you can give 31 days notice to cancel it on there.
Re: Sky cinema
Go into your MySky account, under Your products.
Select Sky Cinema and if your able to cancel,  it wil allow you to there.
If it does not allow you too, you are still in a contract term and will have to wait until that needs.
This message was authored by: Tommy2
Re: Sky cinema
When did you sign up ? if you signed up on a fixed term contract whcih is generally 24 months then you generally cant unless its within 28 days of you signing up, then you will only be charged for what you ahve used. Some Sky cinema contracts on a rolling term let you cancel whenever you like, though, they are more expensive. Either way your best bet is to call Sky and see what you can do. I hope this helps.
Sky Ultimate TV with Sky Cinema on Sky Steam Puck with WI-FI
Sky Full Fibre 500mbps
