Discussion topic: Sky Streaming Remote - Panasonic TV Power
Message posted on 06 Oct 2026 02:00 PM
Hello,
Recently got a Sky Streaming Puck, and when I pair the remote to my TV the volume controls work correctly, but the power button has no effect on the TV, which obviously is pretty frustrating as it means I need to use 2 remotes.
The TV Model is -> Panasonic tx-55fx550b, I've tried 4 or 5 different settings during the remote setup (selecting that no the volume doesn't change even though it does) . Each time it's the same, I can control the television volume but not the power (or AV input)
Is there a way of manually selecting the specific model of TV or something to rectify this, as I'm not sure I want to cycle through x of 44 to find one that works (if there is one that works)
Tah!
Message posted on 06 Oct 2026 03:31 PM
Re: Sky Streaming Remote - Panasonic TV Power
To turn the television and Puck to OFF you need to hold the remote control power button down for about 3-5 seconds, otherwise only the Puck turns OFF. To turn it all back on again only requires a short push on the remote..
