Discussion topic: Sky Streaming PUK device freezes
This message was authored by: ZAhmed5373
Hi
I have recently taken on Sky Streaming and they have sent me a PUK device. It arrived  yesterday in the post 11 Aug 2026.
My broadband is with EE and i'm currently on Full Fibre 150. I have carried out speeds tests and i'm consistently getting 150 mbps.
I had raised the issue EE. EE attempted to connect the PUK device over  2.4GHZ (initally it was 5 GHZ) but this did not work so they reactiviated the 5GHZ connection
When I attempt to watch any of the channels, the load for a few seconds and then freeze and the device becomes unuseable. I've also observed that the device freezes in it's entireity.
This message was authored by: Gincap
Re: Sky Streaming PUK device freezes
https://helpforum.sky.com/t5/Sky-Stream/QS040-040-00P-Issues/td-p/5340063
There are issues with the latest software version which sounds like your issue but your problem could be something else.  Check your software build just in case.
Avatar for ZAhmed5373
Thanks for the response, how do i check the SW build version?
I assume it would be via the UI but that's currently unusable. On the PUK Device I can only see the serial number and the model number.
Press three dots ... Top left remote
Go to settings
System management
System info
interestingly for me, when pressing ... nothing happens nor does anything else on my remote.
The only thing that works for me is the volume control and the mute.
I even tried pressing 1 & 3 to try and reset the remote but no luck.
last night when i tried, I was at least able to navigate to the different tiles in the UI but this does not seem to be the case today.
I'm confident it's not a remote issue.
Also worth noting that you wouldn't be the first customer to complain about having issues specifically with EE and the sky streaming platform.
If you do a search on the forum for EE on the Sky Stream or Sky Glass boards you will see a number of customers posting various problems which i think was related to the EE hub.
Not to say that is definitely the cause of the issue you are having, but its worth checking out in case it is.
Give sky a call could be a faulty puck. Also unplug it give it a mo and try again if no luck....
The hub I have is actually from BT when I was a BT customer. When it was re-branded or when BT was taken on from EE, it was never changed. Do you think that could also be an issue?
I would, but I have no idea how to get through to a human at sky😁
Give Sky a call and just say you want cancellation s you'll get someone.
