01 Jun 2024 07:18 AM
I'm a new sky stream customer and just about to activate it. I currently have Netflix Basic as a Smart Benefit on my mobile EE. This allows me to watch Netflix without any ads.
if I sign into Netflix with Sky Stream will it take over the Basic (which no longer exists), for the Netflix Standard with Ads.
In short - will I start to see ads in Netflix.
01 Jun 2024 09:55 AM
No you will not, if you are using the same email address with EE and Sky, Netflix will see the plan without ads (which is now no longer available) as the higher plan and you will stay on the plan you have with EE. I can speak from confidence as I was In a similar position.
01 Jun 2024 07:36 AM
Yes ... if you use your current account ... create another Netflix account and link that to your Sky account🤔
01 Jun 2024 10:14 AM
Although, you must not link the Sky and the Netflix accounts?
01 Jun 2024 10:48 AM
@Exiled-in-HH wrote:Although, you must not link the Sky and the Netflix accounts?
I doubt he would be able to due to it being done via EE though I could be wrong.
01 Jun 2024 12:12 PM
Nope you can link the sky and Netflix accounts, as you can link the EE and Netflix same account. I have EE and Sky linked to the same Netflix account. Netflix will take the priority from the higher subscription and show that. I am in this position so can talk from a factual position
01 Jun 2024 12:17 PM
Thanks for the replies. I will try linking with my main Netflix and see what happens then. Worse comes to worse I just change the activiation on my EE benefit to a fresh account. Does it remain 720?
01 Jun 2024 01:36 PM
@Robb0 at least you have a plan you are happy with🙂
01 Jun 2024 07:03 PM
Just by way of update - @Jason+Golding is correct in that there doesn't appear to be ads therefore my basic plan from ee has pulled through. Although with the 4k ui, the 720 looks quite bad now and I'm wondering if 1080 with ads would actually be better . Haha.
02 Jun 2024 08:55 AM
Have you checked you Netflix account to see who the Billing partner is?
02 Jun 2024 08:58 AM
@Exiled-in-HH - it says billed through EE package. Basic HD
02 Jun 2024 09:03 AM
If you switch to a Sky service Sky will takeover that account and you'll have to create a new account for the EE service🤔
02 Jun 2024 09:40 PM
@Exiled-in-HH not quite sure what you mean. I've logged into Netflix on sky stream using my main Netflix account (with ee basic) . I just selected the £0 with ads option. However it didn't change my sub which still shows as payable by EE.
03 Jun 2024 06:56 AM
If you change to no ads😉
03 Jun 2024 02:10 PM
@Exiled-in-HH Stop confusing the OP.
OP upgrade to no ads version with EE, its only £3 extra rather than the £6 that sky charge.
