Discussion topic: Sky Stream puck gets through remote control batteries quickly
This message was authored by: singsongfun
Does anyone else find that the remote control for the Sky Stream puck gets through batteries quickly?
Like every one to two months.
This message was authored by: Jporch316
Re: Sky Stream puck gets through remote control batteries quickly
No I've had mine in for over a year
first try repairing the remote
The remote can be reset and paired again following these steps;
  1.   Press and hold 7 and 9 together on your Sky remote for three seconds.
  2.   Press and hold 4 and 6 together for three seconds.
  3.   Press and hold 1 and 3 together for three seconds and follow the on-screen instructions.
if that doesn't work you can request to Replace remote under warranty on link below
https://www.sky.com/help/forms/streaming-tv-remote
@singsongfun Going back to when I first moved to a Glass TV about 3 years ago my initial remote chewed batteries which only lasted about 4 to 6 weeks.  Some other subscribers were reporting the batteries lasted only a few days.  I called Sky and explained the problem and they sent me a replacement remote and I have not had any battery issues since (I no longer have a Glass TV but have a stream puck instead)
Avatar for singsongfun
Many thanks for the helpful replies
