6
This discussion topic has been answered Discussion topic: Sky Stream not working since renewed contract
This message was authored by: Martha2017
Renewed my contract today for exactly the same except cancelled the second Puck as we have never used it. Now none of my Sky Stream is working and says "Whole Home required".
What has happened. Very frustrating that by signing into another contract it has messed up our service. And that this seems to be the only place to ask for help right now.
This message was authored by: mikealanr Answer
Re: Sky Stream not working since renewed contract
Hi @Martha2017
The puck that is in the box unused must be your primary puck.
You will need to make the one you are using primary and send the other back to sky or swap them over.
See: https://www.sky.com/help/articles/your-devices-sky-glass
MikeAlanR
Have you tried both Pucks?
Avatar for Martha2017
The other is still it's in original box unused. Is that likely that it's just the other Puck that is now active?
@Martha2017  The unboxed puck would have been automatically activated even if not in use, check in your Sky account as you may be able to assign the one you use as a primary device, if not you may need to plug the other one in and set it up.
Hi @Martha2017
MikeAlanR
As above, does sound like you have removed your Primary puck.
Do as above and make one of your current Pucks, the Primary Puck.
Thanks all, you were all quite right and the other Puck worked.
Many thanks
