4
This discussion topic has been answered Discussion topic: Sky Stream need an Ariel?
This message was authored by: GeordieMM1288
Just a few questions -
1. Do I need an Ariel to use Sky Steam or just Wi-Fi?
2. My TV is a smart TV already, can I use Sky Stream on it still?
This message was authored by: MarkGoldsmith Answer
Re: Sky Stream need an Ariel?
@GeordieMM1288 Mo you don't need an ariel. The Sky stream puck is a streaming device so only needs to be connected to the internet via an Ethernet cable or via WiFi.
The stream puck comes with an HDMI cable that you just plug into your existing TV.
Avatar for GeordieMM1288
Thanks that's much appreciated.
Can I also check, does anyone know if my TV meets the specs?
it's a Samsung 43Inch UE43TU7020KXXU Smart 4K UHD HDR LED ?
A stream puck will work with most modern TVs. My TV is about 10 years old and has no issues with it
Thanks so much!
