Discussion topic: Sky Stream has a Problem with 1 Minute Skipping
Message posted on 16 Oct 2025 05:56 PM - last edited: 16 Oct 2025 05:58 PM
If you pause live TV for a few minutes say about 5 minutes and then press and hold the play button so it skips it 1 minute, after it doing it a few times it then stops the channel playing and says `There is a technical fault` and will not play the channel until you switch channels.
It looks like its not buffering the channel playback properly.
Looks like a bug to me.
I am not a Sky Engineer but at one time wanted to be one or a BT Engineer... 🙂
I like working things out like its a puzzle... 🙂
I was a PC Engineer and fix peoples PCs by going to there house, Windows XP was known to slow down PCs over time and clog up the PCs RAM and its start-up and had to reinstall it for the customer.
Sky Glass Air 55 inch.
Message posted on 16 Oct 2025 06:17 PM - last edited: 16 Oct 2025 06:18 PM
Re: Sky Stream has a Problem with 1 Minute Skipping
It might not be buffering enough data to do quick 1 minute jumps as the puck only has a small cache.
