Discussion topic: Sky Stream cutting out
This message was authored by: Yekoms1973
Message posted on 19 Aug 2026 07:31 PM
We have sky stream in our living room and the picture keeps cutting out. It happens with live TV and also streaming services.
It is very sporadic and doesn't seem to be any pattern to the cutting out.
After looking online someone suggested doing a hard reset which we have now done and we still have the same problem.
Find out more
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Please note: I am just a sky customer not a employee - posts from sky employees (aka community team) are clearly marked as suchmy setup: Samsung 5 series 32inc tv | sky +hd box | variety, SKY & TNT sports,sky cinema | Netflix and prime video Please note: I only provide help on the main forums and not via PM ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ if this post has helped please give it a like ~ if this post has solved your question/query please mark it as the answer in order to help others
Message posted on 19 Aug 2026 07:35 PM
Re: Sky Stream cutting out
@Yekoms1973 What connection are you using WiFi or Ethernet ? If the former try the latter for a more stable connection
