Discussion topic: Sky Stream constantly looses connection
This message was authored by: LM1805
Constantly having to re connect Sky stream main hub to internet. Any tips? Tried re setting with password and with WPS - still constant issues ... fed up. Not close enough to connect with ethernet cable
Re: Sky Stream constantly looses connection
Try splitting and renaming the WiFi channels on your router so you can choose whether to connect to the 2.4Ghz or 5Ghz channel. One is normally more stable than the other.
