3
This discussion topic has been answered Discussion topic: Sky Stream - can I progamme a second (additional) remote control ?
This message was authored by: JCM18
I need a second remote control and I know I can buy one but before I do can anyone advise if I can programme it so that both remotes will operate.
This message was authored by: lettice Answer
Re: Sky Stream - can I progamme a second (additional) remote control ?
You can pair another remote, but as above only one can pair in Bluetooth mode with the Sky Stream box.
So the secondary remote will only operate as an IR remote, meaning voice will not work.
You can pair an old Sky Q remote, but not in Bluetooth mode if your Sky Stream remote is paired via Bluetooth.
If you have an LG TV, the LG magic remote that is paired via Bluetooth to your LG TV, can operate the Sky Stream box, but no Sky Stream voice though.
@JCM18
Only one Bluetooth remote pairing is possible.
Avatar for JCM18
Many thanks for feedback......very helpful !
Answered - Go to Answer
