1
This discussion topic has been answered Discussion topic: Sky Stream and Sky Go
This message was authored by: MPKPHP
Hi
We currently have Sky Q and are thinking of changing to Sky Stream.
I use Sky Go alot as I work away so watch live sports and download films.  Can I still do this with Sky Stream?
Many thanks
Karen
This message was authored by: Anonymous Answer
Re: Sky Stream and Sky Go
@MPKPHP Yes, you can still use Sky Go with Sky Stream.
I would say though be sure of your decision to switch from Q. You don't have as many channels as on Q and you don't record in the same way - you are relying on the content provider offering the programme for later viewing. Both platforms have their pros and cons - just make sure you research thoroughly if Stream is right for you.
