Discussion topic: Sky Stream WiFi and Ethernet
This message was authored by: Yorkiecherry
I'm connected to the puck by ethernet. WiFi been switched off as recommended. When I switch it on it keeps saying there's no WiFi connection although I am connected by ethernet. The Home screen eventually appears after about a minute or so.  Any clues?
Re: Sky Stream WiFi and Ethernet
@Yorkiecherry  Have you checked in the network settings to see if wifi is still off?
Also have you rebooted the puck since disabling the Wifi ( if it is still showing as off)?
From my own experience it didn't actually turn the Wifi off until after i had turned the puck off at the plug to reboot it.
Avatar for Yorkiecherry
Level 4 icon
Hi. Yes I have
Level 4 icon
I'll give that a try. Thank you
Level 4 icon
That has not worked I'm afraid
