6
This discussion topic has been answered Discussion topic: Sky Stream Suggesting
This message was authored by: RiverbraidHarry
Hi I have an suggestion for Sky Stream on the Home Screen you have only 4 options for continue viewing can you add few more also your Apple TV app does not show Apple Library can you add it also if viewing on Apple TV it is not added to continue viewing on sky screen Home Screen can you add this.
am forced to use Amazon fire stick to view my Apple TV library I like easy access to my library on Apple TV on Sky stream Home Screen.
thanks,
Harold
This message was authored by: MarkGoldsmith Answer
Re: Sky Stream Suggesting
thanks,
Harold
@RiverbraidHarry Thats because Apple have chosen to split the content on their Apps so the Apple TV app on 3rd party devices like Sky is solely for Apple TV ( formerly known as Apple TV +) exclusive content like Ted Lasso, Slow Horses e.g and does not allow access to your personal Apple TV library.
thanks,
Harold
Avatar for RiverbraidHarry
Level 5 icon
But it suggested few movies I watched on Apple TV on Sky stream would like my series like ER to watch it I notice it add discovery plus series but not Apple TV series.
This message was authored by: Nigelb1972
You can add AppleTV content to your Playlist but you have do it from the Sky Stream UI. Easiest way is to do a Voice Search and then press + when you find what you're looking for.
Level 5 icon
Tried that but not allow me add in Apple app
You can't add from the Stream UI to the AppleTV TV app. If you add from Stream, it goes to your Stream Playlist but when you hit the button to watch it, it'll fire up the AppleTV app.
Level 5 icon
Ok thanks will try that
