1
This discussion topic has been answered Discussion topic: Sky Stream Says Poor Signal
This message was authored by: BethanyGreen
On my SKY app it is saying the WiFi may have an issue and that it can't connect to my SKY TV Puck? It says the WiFi connection is poor and not sure why as it is right next to the WiFi and seems to be working fine?
This message was authored by: Nigelb1972 Answer
Re: Sky Stream Says Poor Signal
Reposition either your puck or WiFi hub because the WiFi signal isn't 360degrees coverage so it's probably not catching the signal
