Discussion topic: Sky Stream Puck light
Message posted on 15 Apr 2025 09:40 AM
My Puck light has become very dim. Almost to a point I can not see if it is on. Everything seems to be working O.K. Should i worry.
I am on build QS035.016.00P.
Message posted on 15 Apr 2025 11:45 AM
Re: Sky Stream Puck light
That's odd, but it probably doesn't affect the normal operation of the puck as you've mentioned everything else seems fine. It might just be a dodgy LED. If it becomes a nuisance you could phone Sky and ask for a replacement which they may honour, although for a small issue like this perhaps not.
Keep us posted if there's any further regression though.
Message posted on 15 Apr 2025 12:19 PM
The puck led has always, once on and running, always for me been a rather dim and welcome low brightness led.
Not noticed any recent changes in brightness Myself with recent updates.
Message posted on 15 Apr 2025 07:32 PM
I have also noticed the puck led light is dim when on but not having any problems at all.
Message posted on 18 Apr 2025 01:26 PM
I also noticed yesterday that the light has gone dim.
Message posted on 14 Aug 2025 06:50 AM
The white power on sky stream puck is brighter after qs037.41 software update.
