Discussion topic: Sky Stream Puck keeps refreshing
Message posted on 01 Nov 2025 08:03 AM
Message posted on 01 Nov 2025 08:06 AM
Re: Sky Stream Puck keeps refreshing
@JeremyF18 Keeps refreshing or buffering?
It may be due to poor WiFi or slow speeds. On the puck open the Netflix app, go to Get Help, run connection test, what speed is being reported here.
Message posted on 01 Nov 2025 10:10 AM
Hi,
I wouldn't say buffering as it goes blank for about 1-2seconds and comes back up in HD/UHD without being blurry.
I've done the Netflix test and it is coming back as 67.65Mbps, my Sky Broadband in app is showing as 72.6Mbps. Thanks.
Message posted on 01 Nov 2025 10:35 AM
@JeremyF18 One option, if possble, is to connect an ethernet cable between thepuck & hub, once done go into the setting menu and reset the network to pick up ethernet connection, once done restart the puck.
This may help with stability.
Message posted on 01 Nov 2025 02:59 PM
As I explained to the Sky engineer on the phone, that is not possible due to the distance of the router (phone socket limited) to the TV...! Appreciate your thoughts, but I think Ill have to phone Sky again.
Message posted on 01 Nov 2025 03:05 PM
The picture flickering on and off has nothing to do with WiFi.
When this happens to me I put the puck into standby and back in and it stops.
You could also try a different hdmi lead or try a different port on your TV.
You can also disconnect other hd
Message posted on 02 Nov 2025 10:08 AM
Again, thank you for your response. I have been through all of these options. I have done a factory reset, tried different cables and the issue is still happening.
Sky... any luck you can help?
Message posted on 02 Nov 2025 10:45 AM
@JeremyF18 wrote:Again, thank you for your response. I have been through all of these options. I have done a factory reset, tried different cables and the issue is still happening.
Give them a ring and get the puck swapped.
Message posted on 02 Nov 2025 01:56 PM
Try one of the different picture output settings on the puck . It maybe set on auto - try uhd
