4
This discussion topic has been answered Discussion topic: Sky Stream Puck Return
This message was authored by: Phil001
I've been asked to return a Sky Stream Puck. I'm not sure why I've been asked to return it, as we are still subscribed to Sky. However, we did cancel Multi Room as we never used it and don't believe we have two pucks. Can anyone enlighten me, please? The Sky chat is always closed.
Thanks!
Avatar for Phil001
This message was authored by: Phil001 Answer
Re: Sky Stream Puck Return
Thanks so much for your advice, all sorted now! In my ignorance, I didn't realise we were paying for Whole Home, so Sky made some extra money from us there!
Hi @Phil001
You will need to call sky as this is a customer helps customer community. Whole home subscription allows you to watch on more than one device. While this can be a game console it is usually a 2nd puck. As these are only loaned to you, sky expect them to be returned.
If you are saying you never had a second luck? Why would you have whole home? But in any event you will need to discuss it with sky.
MikeAlanR
Avatar for Phil001
Trying to discuss it with Sky is the difficult part! Thanks for your reply.
This message was authored by: HavencroftKev
You siad you only had one puck, but do you also have a Sky Glass TV or Sky Q?
If you do have a Sky Glass or Sky Q and cancel Whole Home then yes, you will need to return the puck.
If you haven't had any other way of watching Sky and only watched via one puck why were you paying for Whole Home?
Avatar for Phil001
