Discussion topic: Sky Stream HDMI Issue.
Message posted on 14 Aug 2024 06:32 AM
Have had Sky Stream for just over a month now and all fine except for one issue.
I put HDMI on in settings menu and result was that when I pressed home button on Sky Stream remote what comes up is HDMI 3 on my TV which is set to an Amazon firestick.
Any help to resolve this greatly appreciated.
Message posted on 14 Aug 2024 08:00 AM
Re: Sky Stream HDMI Issue.
Have connected the Puck to HDMI 3 and Firestick on a different port?
Message posted on 14 Aug 2024 09:28 AM
Firesticks can be a little temperamental with HDMI CEC control.
Depending on how you have the Firestick and TV set up, the Firestick will detect when your TV is turned on (even if it's been turned on by your Stream puck command) and will automatically switch the TV to the HDMI input favoured by the Firestick, in your case HDMI 3.
Check the HDMI control settings on the Firestick and perhaps try turning them off and see if it sorts the issue.
