Discussion topic: Sky Stream - Favourites access via Mini Guide
23 Dec 2023 04:51 PM
Hi
apologies if this has already been covered.
had Sky Stream since it first came out. Set up my favourites which I used to access via the select button and clicking left to access them.
Can't access them via this method anymore. Obviously a change from a software update.
am I missing something?
21 Feb 2025 10:25 AM
@Stonechat wrote:I've found that when first turned on if you scroll down to TV guide and click on that, a list appears at the left side where you can scroll up and down to find favourites, all channels, TV shows, Kids, Movies etc. The list shows up and disappears very quickly, so you have to be quick! Hope this helps.
If the list does disappear, you can bring it back quite easily by pressing the left button whilst on the TV guide.
