Discussion topic: Sky Stream Dolby Atmos to HDMI eArc on TV
‎25 Nov 2024 02:38 PM
I will be changing my old Panasonic Plasma TV for a brand new Samsung QN90D so that I can take advantage of Dolby Atmos (I will also upgrade my Sky Stream subscription to include Sky UHD / Dolby Atmos).
Will I have to connect my Sky Stream Puck to the eArc HDMI port on the new TV for the Dolby Patmos to work (and will I need an upgraded certified HDMI cable)?
‎25 Nov 2024 05:15 PM - last edited: ‎25 Nov 2024 05:42 PM
@MickMaserati wrote:
I will be replacing my old Panasonic Plasma TV with a new TV with Dolby Atmos capability. I will be upgrading my Sky Stream subscription to include UHD / Dolby Atmos, and will be fitting a new HDMI 2.1 certified cable to my Stream Puc.
To help with my choice of TV, can you tell me if the new TV will need to have an eArc HDMI port to connect the Sky Stream Puc in order that Dolby Atmos will work?
As you are asking a slightly different question to the one you originally posted I have merged your posts rather than just remove the duplicate.
These days I think most TVs will have eARC ports as most have had ARC ports for several years & I think now willhave eARC as that has been out for a while.
Atmos on SKY Stream currently does not need the extra bandwith of eARC over its older standard ARC connection
As per my previous post the Stream should be connected to any other input HDMI input on the TV & then any Sound bar or AV receiver plugged into the (e)ARC port
If you are not using any sound equipment to listen to the Atmos sound but using the TVs internal speakers then in theory you can use the (e)ARC port but in this case the fact it is an ARC port is irrelevant but as I say, really the (e)ARC Ports are intended for Audio equipment
