2
This discussion topic has been answered Discussion topic: Sky Sports keeps freezing
This message was authored by: Alan190
Hello. My Sky Sports channel keeps buffering and freezing. The internet connection is around 17 M per second. It is the only channel that has this problem.
This message was authored by: Hunter2660 Answer
Re: Sky Sports keeps freezing
Your internet connection is below the recommended speed for Stream, 25mbps for HD and 35mbps for UHD, so you will have issues. My recommendation is to connect the Stream box to the router using an ethernet cable and switching the wi-fi off.
Avatar for Alan190
Thank you very much. I already have the device connected to the hub with an Ethernet cable.  I will see if I can upgrade to a better speed if possible. Thanks again.
