2
This discussion topic has been answered Discussion topic: Sky Sports UHD Channels
This message was authored by: Whittdawg
Any ideas why I do not see Sky Sports Main Event UHD on channel 401, just the HD version of the channel. However, if I go to channel 922 - Sky Sports Main Event UHD "Live Sync / Real Time" the UHD programme works fine.
I have the UHD / Atmos pack and everything has worked fine for years.
Avatar for Whittdawg
This message was authored by: Whittdawg Answer
Re: Sky Sports UHD Channels
All sorted now, must have just taken a while to sort itself out.
@Whittdawg  Because that's how sky have it setup
There is no swap out of uhd channels if you have the uhd subscription like there is with hd on satellite
or are you saying you have seen the
uhd version on 401 in the past
