This discussion topic has been answered Discussion topic: Sky Q remote for Sky Stream
Message posted on 12 Sep 2024 04:36 PM
Hi,
I just wanted to check if anybody has tried using Sky Q remote with Sky Stream as I have just got Sky Stream but I hate it that there are no separate channel change buttons and there is no way to go directly to live tv from remote as was the case on Sky Q or Virgin Stream. Sky Q does have these buttons and want to check if that remote works with Sky Stream and does Live TV button works?
Message posted on 12 Sep 2024 08:48 PM
@AamirArrar The "SKY" button at the top of the Q remote doesn't do anything. Also, as the Q remote only works in the IR mode it also won't control the volume on my Samsung TV which needs to be a bluetooth signal.
Message posted on 12 Sep 2024 06:52 PM
Re: Sky Q remote for Sky Stream
I'm sure I read somewhere that after a recent update you can no longer use q remotes on stream/glass
Sky Q 4K HDR Box
Sky Multiscreen
Sky Signature with Netflix. HBO Max and Disney +
Sky Sports Complete Pack
Sky Cinema
Sky HD and UHD Pack
TNT Sports
Virgin Media Gig1 Broadband
Sky Mobile Iphone 18 Pro Max 256GB Burgundy. Unlimited SIM
Message posted on 12 Sep 2024 08:30 PM
Hi @AamirArrar welcome to the forum. I use a Sky Q remote as a secondary remote. I used to be able to set it up as bluetooth but since the last update QS030 I have found it only works in IR mode. This doesn't bother me as it is not my main remote.
The Glass / Stream remote is pretty poor quality compared to the Q remote.
Message posted on 12 Sep 2024 08:35 PM
Thank you for the response. Does live tv button and channel change buttons of this remote work with Sky Stream?
Message posted on 15 Oct 2024 04:46 PM
Hi
We just got Stream and I was hoping I'd be able to use one of our old Q remotes in IR mode as a secondary remote. However, I can't seem to pair it at all and currently only the home button works. Is it possible to set up with the current software version?
Message posted on 15 Oct 2024 08:10 PM
Hi @ChrisN82 Yes it should pair in IR mode whilst using the latest software (QS030.528.00P) as my old Q remote is in daily use with my Stream puck as a secondary remote. I have found that it doesn't work in bluetooth mode though.
The pairing process is the same as pairing a standard Stream or Glass remote.
Message posted on 15 Oct 2024 08:25 PM
Thanks @Fothergill1 I've tried pairing both my Q remotes but nothing happens (I've un-paired and re-paired the Stream remote fine so I think I'm following the right process). I wonder if your remote works because you paired it before the software update.
