3
Discussion topic: Sky Puck remote
This message was authored by Claire59 This message was authored by: Claire59
Sky Puck remote
My Sky Puck remote has decided to stop working.
The screen tells me to hold 4 and 6 together for 2 seconds. I've tried this multiple times.
I've changed the batteries. The light comes on in remote.
I've tried holding down 7 and 9. I've tried 1 and 3
Any ideas?
This message was authored by Fothergill1 This message was authored by: Fothergill1 Answer
Re: Sky Puck remote
@Claire59Have a look at the links below are to remote troubleshooting guides to see if anything there helps you.:
Troubleshooting guide
Remote help
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth.  Even though it sounds an unlikely solution it has got many faulty remotes working again (including mine).
If none of the above help then I would request a replacement by completing the request form at the following link: Streaming TV replacement remote  (if you sign into your My Sky account first the form will be partly completed with some of your relevant details).
If you have one available you can use a Sky Q remote while you wait for a replacement.
If my post has solved your issue please mark as an "Answer"
Re: Sky Puck remote
Remote help
Claire59
Re: Sky Puck remote
@Fothergill1  Thank you so much for your reply. I used the link you sent to get a new remote, it arrived today and Sky is back up and running.
Appreciate it, Claire
Re: Sky Puck remote
@Claire59 Your welcome, the forum is all about helping each other when we can 😀.  That's a pretty quick order to delivery turn around so I'm glad your up and running so quickly.
