Discussion topic: Sky Puck Remote/LG TV
Message posted on 16 Dec 2024 03:52 PM
Hope someone can advise. We have a Sky puck and an LG tv. We can pair it ok and it controls it ok and will turn it off. The problem we have is when turning the tv on, it doesn't go to the right input so I have to use the tv remote to go the the right input. It's not a big thing but is annoying as it did turn it on direct to Sky at one point. We have done resets on both.
Message posted on 16 Dec 2024 06:51 PM
Re: Sky Puck Remote/LG TV
What CEC do you have set on TV and puck?
How are you activating the puck?
Message posted on 16 Dec 2024 07:26 PM
We just plugged it in and followed the instructions. It works fine apart from that one issue. What is CEC? Sorry, not very technically minded.
Message posted on 16 Dec 2024 08:38 PM
HDMI control between devices😊
Message posted on 16 Dec 2024 08:39 PM
Thanks - will have a look and see what I can sort out.
Message posted on 16 Dec 2024 09:23 PM
It's sorted. Thank you so much.
