Discussion topic: Sky Puck - No connection
Message posted on 26 Aug 2025 09:07 PM
Message posted on 26 Aug 2025 10:54 PM
Re: Sky Puck - No connection
So your booster etc should be unrelated as that is your internet. When you power on your puck and you see the logo, after it goes off wait a few minutes and press the home button on your remote. Does the white light come on on the front of the puck?
If not flip your puck over and press the button on the bottom. Does this turn it on?
If the white light is on but your not seeing an output you may need to check the settings on your TV to ensure the match what the puck is outputting. Maybe post the make and model.
Let us know if it's turning on and we can give some next steps.
MikeAlanR
