Discussion topic: Sky Puc Connection Issues
Message posted on 14 Aug 2024 12:55 PM
Hi,
Has there been a recent update on the Sky Puc. Recently when i turn the puc on it says its not connected to the Brodband, go to connection and it connects stright away.
Used to be able to turn ir on and it would work stright away.
Message posted on 14 Aug 2024 03:35 PM
Re: Sky Puc Connection Issues
Yes ... recheck you power saving options:lia_thinking-face:
Message posted on 14 Aug 2024 05:18 PM
@Staceymay88 Make sure your Networked Standby Mode is still turned ON (when in standby it stops the puck losing the netwwork connection).
You can find it in the Settings > Start up & Standby menu.
