Discussion topic: Can I use my sky satellite dish with sky stream
Message posted on 14 Aug 2024 05:31 PM
Can I use my sky satalite dish with sky stream @Skyhelp
Message posted on 14 Aug 2024 05:34 PM
Re: Can I use my sky satellite dish with sky stream
@Chris309 no you can't I'm afraid
you have tagged a fellow customer who unfortunately used an unfortunate name rather than sky support
Message posted on 14 Aug 2024 05:35 PM
Message posted on 14 Aug 2024 05:37 PM
@Chris309 wrote:Can I use my sky satalite dish with sky stream @Skyhelp
In a word, no. The Stream box itself streams content over the internet, either via WiFi or Ethernet, and has no interfaces for cables from a dish.
Additionally, Sky will only allow a Stream subscription or a Sky+HD/Sky Q subscription at a given address, not both. So even if you have a Q and a Stream box, only one can work with the appropriate subscription.
Message posted on 14 Aug 2024 05:54 PM - last edited: 14 Aug 2024 05:56 PM
Depends on the LNB on the dish and whether your Smart TV can be connected to a sat dish🤔
If you have Sky Q the LNB will need to be changed ... if you have Sky+ the LNB can supply a sat signal to a Smart TV with a DSat tuner😉
