Discussion topic: Settings .
This message was authored by: Bluemoon1
Settings .
Hi I have just found that the settings can be accessible from the three dot  button on the remote. .Press it and scroll to setting and it will take you straight to the settings rail, without having to scroll through 20 other rails. Not sure how long this option has been there..
Re: Settings .
Hi @Bluemoon1
Yes this has been there for a good while.
MikeAlanR
This message was authored by: Nigelb1972
Re: Settings .
You can also just say "settings" into the remote or wherever the microphone is ..
