Discussion topic: Setting up issues
Message posted on 04 Oct 2026 08:40 PM
Setting up issues
Just setting up my Sky Tv Stream with my new puck and it's stuck in a loop of'letd get connected...' then 'updating software...' then it switches off and on and goes back through it again on a loop! I've reset it, switched it off and on about 5 times and left it for an hour to run to see if that would work but nothing! Any help greatly appreciated.
Message posted on 04 Oct 2026 08:59 PM
Re: Setting up issues
Hi @Carlyle34
Try following the steps outlined here: https://www.sky.com/help/articles/setting-up-sky-glass-updating-software
MikeAlanR
Message posted on 04 Oct 2026 09:53 PM
Hi! I've tried that a couple of times, not sure the remote is linking up as it doesn't flash.
Message posted on 04 Oct 2026 10:16 PM
Hi @Carlyle34
Take the back off the remote and make sure that no paper has stuck in it from removing the tab. Failing that you will need to speak to sky.
https://www.sky.com/help/articles/remote-control-help-sky-glass
MikeAlanR
