Discussion topic: Setting up Sky Stream
This message was authored by Newuser22 This message was authored by: Newuser22
Just received my sky stream in the post and gone to set up. All cables are in correctly and not loose. The device 'loads' up, I get a black screen with 'sky' appear and then 10 seconds later the screen goes blue. No such 'menu' or 'set up' or anything to that matter displays on screen.   I have tried every possible solution I could find online, unplugging, restarting etc but nothing works. Without initially being able to set up means I cannot set up the control either. A few of the troubleshooting problems suggest using the controler, but without being able to set that up in the first place I'm completely lost! I just want to enjoy some shows haha
This message was authored by Tim+Adams This message was authored by: Tim+Adams
Re: Setting up Sky Stream
Hi @Newuser22
Switch the Stream off at the socket, wait a min then back on.
Now leave it for a few mins then press the power button under the Stream which should turn  it on, do you now see the setup screen?
Thanks,
Tim
Sky Glass with Sky Live, Sky Stream & Sky Protect - FTTP 2Gbps
Newuser22
Thank you for responding!
I have followed your steps but still no success. After switching off the mains, I waited a minute and the same thing happens. The black sky screen appears and then straight away a blue screen. The light on the sky stream was flashing on and off and then eventually turned off. I tried clicking the power button underneath but nothing happened!
Hi @Newuser22
I've escalated this to Sky who will invite you to chat and troubleshoot. Below is a link about how it works - please look out for the chat bubble
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Thanks,
Tim
This message was authored by Addie15 This message was authored by: Addie15
Posted by a Sky employee
Hi there! Thank you for escalating this. We have sent Newuser22 an invite.
This message was authored by Lisa-P1987 This message was authored by: Lisa-P1987
Update - Spoken to @Newuser22, after a few checks, they have had to call our Glass Tier 2 Team 🙂
Lisa - Sky Tech Team Expert
