Discussion topic: Samsung TV - Sky Stream remote won't control it...:(
Message posted on 20 Aug 2024 07:28 PM
Hi All, I recently bought a new TV for the bedroom. It is a Samsung T5300 (Full model code: UE32T5300CEXXU). I go to set up the remote, but after going through all the 21 options and the 8 Samsung specific options it says that my TV can't be found and I will have to use the TV remote...
I am struggling to believe that a fairly basic Samsung TV that isn't even a very new model won't work with the Sky Stream remote?!
I have even been sent a new replacement Stream remote by Sky and that doesn't work either...
I have tried the usual 7 and 9 then 1 and 3 button reset and reconnections, but still no joy...
Any assistance or ideas would be appreciatted. Thanks!
Message posted on 20 Aug 2024 07:59 PM
Re: Samsung TV - Sky Stream remote won't control it...:(
Try a long press on the Sky Stream Remote. We have a Samsung in the living room and a short press turns off the Puck and a long press will turn off the Puck and then the TV..
Message posted on 20 Aug 2024 08:04 PM
Thanks. Yes, I have tried that but sadly it doesn't control the volume or the power.
Message posted on 20 Aug 2024 08:06 PM
Have you enabled CEC on the HDMI input?
The Puck remote does play nicely with Samsung TV's.
Message posted on 20 Aug 2024 08:11 PM
Good question.... I haven't! I will check that setting. Thanks.
Message posted on 20 Aug 2024 10:07 PM
Hi. I checked that CEC was enabled, which it was. Sadly still the same issue when trying to set up the remote to control the TV.
