Discussion topic: SKY Stream CHANNEL 101
This message was authored by: tvboy55
Channel 101 BBC keeps jumping to another random channel  mid program . Anyone else having this issue . Have to do a reboot to stop it .
This message was authored by: Dazzasky
Re: SKY Stream CHANNEL 101
If you go into the puck settings you can do a restart of the puck or pull the plug for 30 seconds @tvboy55 If it keeps happening then I would contact Sky directly
Avatar for tvboy55
Level 5 icon
Thanks that is what I am doing . Will contact Sky if it carries on much longer .
It's strange as I've not heard off this happening before. You could try a factory reset but it's not advisable without the assistance of Sky due to some people running into issues after. @tvboy55
Avatar for tvboy55
Level 5 icon
It's only just started happening not sure  if we have had a firmware update recently .  I have done factory resets in the past thanks very familiar with them .
