Discussion topic: Roku sound bar and stream
Message posted on 12 Aug 2024 09:32 PM
Hi today I got a new samsung smart tv. Loaded roku sound bar - accessed roku no problem from the samsung home page on my tv. Later on in the day my stream box arrived
installed it - but now when I go to Roku it will load but then when trying to watch a channel or load an app from within the roku system it starts to load then just takes me back to the ROku home screen.
Also I can see no way to click from stream into Roku - when i click the roku remote it makes the sound but does not load roku
I have the sound bar on hdmi/1 arc
and then stream on Hmdi 2
any idea anyone ? thanks
Message posted on 12 Aug 2024 09:52 PM - last edited: 12 Aug 2024 09:56 PM
Re: Roku sound bar and stream
Conceivably the introduction of the Stream puck is causing interference with the Roku hardware: are they physically distanced or adjacent?
That suggests the television is not sensing the Roku input correctly. There cannot be a direct 'way to click from stream into Roku ': the television has to change HDMI input
I'd have to say that a soundbar with an onboard video streaming app is a rather unusual bit of hardware...
Message posted on 12 Aug 2024 10:10 PM
Hi okay so yes no direct way from Stream to Roku get that. There is distance between the puk and the rokue sound bar. And the Roku streambar is basicially a sound bar with roku installed on it - had it 2 years it is really good sound - goes into the arc hdmi.
But something stopping me loading apps/channles within roku since I installed stream. restarted network - checked settings - no good. maybe the roku soundbar cant work with stream ...
Also the new samsung tv is great but when I start the TV by default it loads the samsung home page and not straight into the sky stream page. Is there any way to change this ? thanks
Message posted on 12 Aug 2024 11:00 PM
weird found the issue when I set the TVS default audio out put to the roku sound bar it wont load / play any apps from within the roku interface. Knock it off for the samsung built in audio - apps then work. Never had this before and the samsung sound is not as good as the roku sound bar... did not happen before i installed the sky puk.
Message posted on 12 Aug 2024 11:04 PM
@dino9898 wrote:weird found the issue when I set the TVS default audio out put to the roku sound bar it wont load / play any apps from within the roku interface. Knock it off for the samsung built in audio - apps then work. Never had this before and the samsung sound is not as good as the roku sound bar... did not happen before i installed the sky puk.
Get a CEC blocker from Amazon. The Stream pucks are known to send out spurious CEC commands, even in standby, which can affect other devices attached to your TV. I had to do this with my puck. Sky refunded me the cost of the blocker as it was a fault of the puck.
