Discussion topic: Replacement remote issues
This message was authored by BFisher This message was authored by: BFisher
My dog decided to eat my original remote from my skystream one box. I had a hard time finding a new one for that application but I found a remote on Amazon.uk. The remote it titled "
Sky Glass and Sky Stream TV Remote - Anthracite Black"
After reading some reviews it sounded like it would work on my box. Getting it in the mail, it wouldn't work directly from the box. I could get it to pair with the television but not control the box. I've tried holding the 7/9 buttons to unpair it and then 1/3 to repair it. I can't figure out how to get the remote to pair with my skystream one box. Anyone help? I may have to send it back to get another option on a remote
This message was authored by Padam_Padam This message was authored by: Padam_Padam
Re: Replacement remote issues
@BFisher
The Sky Glass/Stream remotes are sadly a bit of a car crash. There have been reports pretty much on a daily basis of them either not working, stopping working, losing Bluetooth control, batteries exploding, and just general uselessness.
The one you bought from Amazon should work, but it's from the same mass-production line where quality control is sadly lacking.
You could always try for a replacement from Sky themselves and see if you get a better one:
https://www.sky.com/help/forms/streaming-tv-remote
BFisher
I've tried thst twice and haven't heard a peep back about a replacement remote
This message was authored by Jporch316 This message was authored by: Jporch316
@Padam_Padam wrote:
@BFisher
For a bit of context  I've had 4 remotes since April 2022 and not had a problem.
I really like the layout and feel and the backlight is the cherry on top
43inch and 55 inch Sky Glass & 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims. Pretend guitar aficionado .. rock on!
This message was authored by Exiled-in-HH This message was authored by: Exiled-in-HH
@BFisher when did you submit the requests for replacement remotes?
BFisher
I did for the second time last Monday, 3/11. I just need a way to control my box. Even if it's something else.
This message was authored by Munkeh This message was authored by: Munkeh
Hey,
If you haven't heard from sky when completing the replacement forum you can contact Sky Stream team call them and explain and they will ship on out the next day replacement :).
Hope this helps.
Two Stream Pucks (Both ethernet)
OGI 900 FTTP (900Mbs), eero Max 7 & 3 x eero Pro 6E
If my post has solved your issue please mark as an "Answer"
BFisher
Have a contact number handy?
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
You can call on 150 from a Sky Talk Line or Sky Mobile.
https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number. If you are in the ROI on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Sky Stream and Sky Broadband customer
