Discussion topic: Remote only half works
This message was authored by: Jo280
Message posted on 24 May 2025 02:26 PM
I've changed the batteries but I can only turn sky on and off or volume up and down. I can't change channels or get the menu or in fact anything else. I have turned it all off at the wall , turned the box off for an hour ! Please help!
Find out more
Message posted on 24 May 2025 02:53 PM
Re: Remote only half works
Try re pairing your remote
- Press and hold 7 and 9 together for 3 seconds.
- Press and hold 1 and 3 together for 3 seconds.
- Wait until you see the 'Your remote is now connected' message and select Continue.
More info here;
https://helpforum.sky.com/t5/forums/replypage/board-id/sky-stream/message-id/52180
Sky Community Superuser. What is a Superuser? Click here to find out
