Discussion topic: Remote not working
This message was authored by: Eutecia
Remote not working
The remote for my sky stream is not working for my second tv
Re: Remote not working
@Eutecia  To help you try to get your remote working the links below are to remote troubleshooting guides:
Troubleshooting guide
Remote help
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth.  Even though it sounds an unlikely solution it has got many faulty remotes working again (including my own).
If none of the above help then I would request a replacement at the following link: Streaming TV replacement remote
If you are lucky enough to have one available you can use a Sky Q remote while you wait for a replacement to arrive.
