1
This discussion topic has been answered Discussion topic: Remote not working
This message was authored by: Matthewwig82
Remote not working
My remote does not work properly for my new sky stream puck I put new batteries in the remote and it went pop. Now it doesn't work. Can I have a new one?
This message was authored by: MarkGoldsmith Answer
Re: Remote not working
Have you tried resetting the remote?
Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
Press 1 and 3 together for three seconds (bluetooth mode) and follow any on-screen instructions.
The next option sounds insane but a number of users have reported it resolving the issue with their remotes. You could try holding the remote at both ends and giving it a gentle twist as though you were wringing out a towel.
If none of these options work you can request a replacement remote via this link: https://www.sky.com/help/forms/streaming-tv-remote
