Discussion topic: Remote not working
This message was authored by: 12345Lloyd
Remote not working
Remote isn't working tried resetting it and still doesn't work
This message was authored by: Jporch316
Re: Remote not working
@12345Lloyd
First check the batteries
then try
The remote can be reset and paired again following these steps;
  1.   Press and hold 7 and 9 together on your Sky remote for three seconds.
  2.   Press and hold 4 and 6 together for three seconds.
  3.   Press and hold 1 and 3 together for three seconds and follow the on-screen instructions.
failing that follow the below link to Replace remote under warranty
https://www.sky.com/help/forms/streaming-tv-remote
