Discussion topic: Remote control problems
This message was authored by: Mac4Shaz24
Paper strip stopping batteries from connecting ripped when I tried to remove it. Can't see how to remove the remaining paper to get my remote working. Can anybody help me please???
Re: Remote control problems
@Mac4Shaz24  Pleasee the instructions here https://www.sky.com/help/home/sky-tv/sky-tv-stream/fixing-a-problem-sky-stream/fixing-sky-glass-remo...
This message was authored by: martswain
If you are finding it difficult to get a grip on the remote put on a pair of rubber gloves.
You only need to slide it a few mm to get the back free.
Avatar for Mac4Shaz24
Cannot remove back from puck remote
@Mac4Shaz24 you'll have to keep trying, make sure you are moving it in the direction of the very small arrow.
@Mac4Shaz24 it can be tough getting the back off the remotes I lay them face down on a towel or on a carpetted floor and use. The flat of my hand to slip the back down in the direction of the arrow - the back moves a little way.
