This discussion topic has been answered Discussion topic: Remote not working
Message posted on 17 Dec 2023 11:54 AM
I have woken up this morning and the remote for my sky stream isn't working at all.
The button to move left on the remote instead turns off the box. The button to move right opens the search bar.
I have turned the tv and box off multiple times, and left it off for a couple minutes also. I have aswell, restarted and reconnected the remote per google searching my problem.
Nothing has worked so far so any help/advice would be greatly appreciated.
thanks, robert
Message posted on 17 Dec 2023 11:57 AM
Try some of the suggestions below, hopefully one helps:
Check the batteries
An easy way to check is to cover the buttons slightly on your Sky remote with your hand. You should see a white backlight behind the buttons. If you don't see the backlight the issue is the power with the remote, so potentially a battery issue.
Check the battery compartment to make sure the paper used to protect the battery has been fully removed. It might have ripped when being removed leaving some behind.
Still can't see the backlight? It’s likely you need to replace the two AAA batteries.
Pair the remote
Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
Press 1 and 3 together for three seconds (bluetooth mode) and follow any on-screen instructions.
The next option sounds insane but a number of users have reported it resolving the issue with their remotes. You could try holding the remote at both ends and giving it a gentle twist as though you were wringing out a towel. It
If it is still not working have a look at the following guides:
https://www.sky.com/help/articles/remote-control-help-sky-glass
https://www.sky.com/help/home/sky-tv/sky-tv-glass/fixing-a-problem-sky-glass/fixing-sky-glass-remote...
If none of these options work you can request a replacement remote via this link: https://www.sky.com/help/forms/streaming-tv-remote
If you have an old Sky Q remote, you can use that as an interim solution whilst you await the new remote.
Check the batteries
Pair the remote
Message posted on 17 Dec 2023 12:14 PM
Re: Remote not working
Thank you, the battery's were working with the backlight ect, I opened the back of the remote and a battery had popped inside. Replaced this and now all seems to be working. Thanks again.
Message posted on 05 Jun 2024 08:26 PM
Sky stream Remote not working
Re: Remote not working. I have tried all the various options suggested but nothing works.
