Discussion topic: Remote control for Sky Puck
This message was authored by: Gertie58
OK, so I waited 6 days for a new remote to arrive so that I could resume watching sky tv. The remote switches the puck on and navigates through the channels, but it will not control the volume. Is there a quick fix or have I got to get another new remote? I have a Panasonic tv.
Re: Remote control for Sky Puck
Did you pair the replacement remote with same code as the original remote that did control volume?
Avatar for Gertie58
Hi, I didn't do anything with the new puck,there was no paperwork with it. Sky should provide info on what needs to be done, I thought it was ready to go!
It's all online.
All the Sky help guides are available on the Sky help website and also a number are in video format on their YouTube channel.
@Gertie58 If you go to Settings > Connected devices > Sky Remote you will find an option to "Control your TV".  Follow the onscreen instructions and hopefully it will find the correct setting/code for your TV.
Good luck 🤞
Did you receive a new puck or new remote?
