Discussion topic: Re: My sky keeps going off
This message was authored by: John196503
My sky is on but when i select a channel it says loading then after a minute flicks back to the menu screen - is there an issue ?
@John196503 do you have a Sky Q box or do you have a Sky stream box or Glass TV ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for John196503
I havent got a clue - comes in off the internet - my bt one is working fine
@John196503 you have Sky stream so i have moved your post to the Sky Glass/Stream forum
