Discussion topic: Re: I need a new remote control
This message was authored by: Wet22x
Only some buttons are working clean reset and still not working.
Can you first work your way through the Sky help article linked below, to see if that fixes your issue.
If none of that works, you can order via an online form a replacement remote control at the end of the same Sky help article;
https://www.sky.com/help/articles/remote-control-help-sky-glass
This message was authored by: Jporch316
@Wet22x
There is a sky remote app you can download from the android / ios app stores that can pair to your device if required.
